I have received my new DLT tape drive, installed it and in windows xp, when I go to the device manager, it's listing what appear to be 15 identical devices. When I go to the properties for them, I notice there is a tab called "Tape Symbolic Name" For each device listed, in its associated tab, there is tape0, tape1, tape2...tape14
Is this normal? I was just expecting there to be one device listed since I have one drive.
Thanks..
	Sounds like it installed some kind of jukebox layout for multiple tape cartridges, these often have a feature like this. Probably a way to disable it somewhere.
	I'm diving into the 400+ page manual for this thing now.... It appears to have something to do with the SCSI ID, but I'm new to SCSI in general so I need to read up..
	ok, solved the problem. Had the same SCSI ID selected for both the card and the drive. After changing it, everything appears to be working.
	Good deal. IDs and termination, two new things to deal with in SCSI systems.  But they do work well once they are set up properly. But they do work well once they are set up properly.
 I still have a vintage Amiga computer that I may revive that uses SCSI peripherals. I have a SCSI flat bed scanner, an magneto-optical drive and a Zip drive. But my SCSI setup uses the huge Centronics 68 pin connectors and cables. I think I paid more for the scanner and the magneto-optical drive years ago than for my latest Windows PC.
	Never forget the auto termination and master id of the scsi controller.Originally Posted by sdsumike619
 I started into the scsi world with my Amigas too.
	I just received my DLT tapes in the mail, I didn't know they were so beefy/heavy.. Downloaded the utility to test the DLT so I'm going to run that and see how it goes..
  NVIDIA GTX460 'no audio devices installed'By THX-UltraII in forum Newbie / General discussionsReplies: 3Last Post: 17th Apr 2012, 15:41
  Substitute a USB audio device for dead laptop soundcard? [SOLVED]By usually_quiet in forum ComputerReplies: 14Last Post: 2nd May 2011, 00:17
  Hard disk damage or corrupt boot manager? [Solved]By Sakuya in forum ComputerReplies: 15Last Post: 5th Jun 2010, 00:33
  Trying to locate a device in Device ManagerBy alegator in forum ComputerReplies: 2Last Post: 13th May 2009, 11:53
  External drive not showing in Device ManagerBy alegator in forum ComputerReplies: 15Last Post: 10th Dec 2007, 13:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			![[_chef_]'s Avatar](customavatars/avatar30571_1.gif)
